You can export the component list as txt file from Sprint Layout and press convert in the Excel to open a file selection dialog window.
The order of the fields in the export txt is irrelevant as the file will detect them by itself. The only thing you need to take note of is the delimiter (by default a semicolon) and if you want to add the component numbers used by JLCPCB I suggest to add it in the comment field of a component. If you do not want to use it, leave the field blank in the Excel.
Enjoy and if you have any questions, let me know. You are free to distribute it, but please be a gentleman and mention my name
