FXCore Module - Compact Dev Board [documentation]
So Experimental Noize came out with a DSP tailored for pedals.
However the FXCore is not as easy to incorporate in a circuit as the FV1 is.
That's why I made this very compact devboard (only 30 by 43mm). Also, it's breadboard compatible for easy prototyping.
It takes care of the audio conversion and helps to simplify the program selection.
There's a small microcontroller that converts an analog input into a 4bit selection code for the DSP.
This way any pot or switch can be used to select a program.
I had some problems with soucing the right power module. So I made two versions, the first with a simple linear regulator that can take up to 5V and the next version will accept up to 36V.
The next step will be to make a PCB to develop on a pedal format, I'm thinking of a 1590BB size at the moment.
Another related project I'm working on is an open source I2C programmer for the FXCore. In my opinion it would be better than buying it from a distributor as the stocks are pretty scarce.
Here's the Github repo : https://github.com/ElectricCanary/FXCoreModule
Here's the product page : https://electric-canary.com/fxcoremodule
Science is art. Art is science.
- Reachahighernoon
There's still no graphic user interface to program the FXcore, right?
Either way dude, this is friggin awesome
Nope, no graphical programming yet but a guy is working on it : https://github.com/leoschofield/FXCoreDesignerReachahighernoon wrote: ↑01 Apr 2022, 14:47 There's still no graphic user interface to program the FXcore, right?
I'll try to help him when I get the time
Thanks !
- Reachahighernoon
Is there a way someone like me with no knowledge of coding can contribute?Bononoob wrote: ↑01 Apr 2022, 17:35Nope, no graphical programming yet but a guy is working on it : https://github.com/leoschofield/FXCoreDesignerReachahighernoon wrote: ↑01 Apr 2022, 14:47 There's still no graphic user interface to program the FXcore, right?
Thanks !
Not sure for now but the app will need beta testers at some pointReachahighernoon wrote: ↑01 Apr 2022, 14:47 Is there a way someone like me with no knowledge of coding can contribute?
- Reachahighernoon
Then how can I contact him to try, that is if he even needs beta testersBononoob wrote: ↑02 Apr 2022, 12:26Not sure for now but the app will need beta testers at some pointReachahighernoon wrote: ↑01 Apr 2022, 14:47 Is there a way someone like me with no knowledge of coding can contribute?
https://www.facebook.com/leo.schofield.56Reachahighernoon wrote: ↑02 Apr 2022, 12:46
- Ripthorn
Super cool! I've been wanting to get into DSP effects for a bit, but I'm still mining the depths of PT2399's, ES560xx, and microcontrollers at the moment...
Exact Science is Not an Exact Science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
- Reachahighernoon
- Ice-9
Nice project, I was going to do something along the same lines but have put it off due to the shortage of Codec chips. Love the idea.
Thanks! Yeah convertors are getting pretty scarce nowadays. Hope it'll get better once AKM gets back on its feet.
- Ice-9
Yes agreed, I am waiting on AKM getting back into production. I did manage to get hold of 15 x AK4619 4 in/4 out pre production codecs a while back but if you only need 2 in/2out then I think Coolaudio have stock of the V4220 codecs which are clones of the Cirrus Logig CS4220.
I might switch to the Coolaudio chip since it's so cheap. I liked the idea of directly connecting 9V to the board but the TI power module I want can't be found.Ice-9 wrote: ↑27 Apr 2022, 21:38 Yes agreed, I am waiting on AKM getting back into production. I did manage to get hold of 15 x AK4619 4 in/4 out pre production codecs a while back but if you only need 2 in/2out then I think Coolaudio have stock of the V4220 codecs which are clones of the Cirrus Logig CS4220.
So 5V to the board for the 4220 then 3V3 internally for the DSP could be an acceptable solution.
- Ice-9
You could always put a 5v and 3.3v reg on the module so that you can supply 9v to the board, this would mean different versions of your module always run from a 9v supply.Bononoob wrote: ↑01 May 2022, 21:06I might switch to the Coolaudio chip since it's so cheap. I liked the idea of directly connecting 9V to the board but the TI power module I want can't be found.Ice-9 wrote: ↑27 Apr 2022, 21:38 Yes agreed, I am waiting on AKM getting back into production. I did manage to get hold of 15 x AK4619 4 in/4 out pre production codecs a while back but if you only need 2 in/2out then I think Coolaudio have stock of the V4220 codecs which are clones of the Cirrus Logig CS4220.
