Voltage Doubler for tube preamp
phase396
Post by phase396 »
I want to use two 12 volt filament transformers back to back followed by a voltage doubler to power a marshall style tube preamp. The voltage doubler is a full wave bridge rectifier with two of the diodes replaced with two capacitors. (You all probably allready know this.) My question is how large and what voltage should the capacators be? I haven't found many schematics on this but the ones I've found range from 10uf to 330uf. I'm using two 12ax7s. The voltage doubler is converting 120 volts to about 340volts. Any help would be appreciated Thanks..
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi phase396,
Usually a 12AX7 draws 1 mA per triode section, so you need to supply a small current (but well filtered) to feed your preamp.
The voltage doubler you describe can be implemented with two electrolytics of 33 or 47uF rated at 250 Vcc or more.
But take into account that a voltage doubler is equivalent to a half wave rectifier regarding the ripple content so you need several RC sections after the doubler to have a cleaner supply source to your tubes.
As the current involved is so small you can employ also 33 or 47 uF -with adecuate voltage rating this time- and several Kohms in each RC section without much voltage drop.
BTW the filament supply taken from the intermediate connection between transformers can't be floating and must be referred to ground. This is valid if you are planned to use AC or DC to feed the heaters.
Good luck with your project and keep us posted (schematics please !) about your work 8)
phase396
Post by phase396 »
Thanks for the info ppluis0 ! The preamp is a Jose style modded Marshall preamp, which to me, is somewhat like aJCM800. But there are differences. I got some info on it from a you tube video from Ossie Ahsen from 3Monkeys amplifiers. It's titled "My real Jose modded 1979 Marshall 100 watt head." In it he goes through the amp's circuit in great detail. The most clever thing about it is perhaps the master volume which can be placed before the tone stack with clipping diodes or after the tonestack without the diodes. My preamp is silmpler, with one channel, and with a conventional post tonestack master volume and no clipping diodes. The preamp I've built has a fair amount of noise, but the underlying tone is quite good!! I have it on a breadboard with long wire leads. So that could be contributing to the noise. I'm using four 22uf/ 500v filter caps plus three 10k dropping resistors between them. Do you think that's enough filtering? Oh, and I'm using two 10uf/250v caps for the voltage doubler. If you check out a you tube video titled " Marshall 1959 HW-stealth Jose mod. tones & DIY guide" by Headfirst Amplification you can see pretty much the exact schematic of the preamp I'm working on (minus the clipping diodes and switchable bright caps.) Thanks again ppluis0, just thought you might be interested in some more detail.
ppluis0
Post by ppluis0 »
Hi phase396,
I will see the videos you mentioned to know about this mod on Marshall amps.
(If the person who modified these amps is called Jose like me, then he must be a great guy... :mrgreen: )
