LAL GMR Gomorrah (Lastgasp Art Laboratories)
- karul
I could be wrong but my guess is that diode is zener. Small signal diodes won't work, they will block the current flow from the LED. I don't know what kind of LED they have used but that 4.7k is bit to high for regular red LED. For current around 5mA min for LED to emit light that resistor should be lower e.g. 1k will do with zener cca 3-4V. I'm not sure why they used that arrangement.
- ppluis0
Hi pals,
After take a look at the schematic of a Boss SD-1 found that pedal (and almost all Boss series) employs zener of 5.1V and 3.9K in series with the indicator led.
This way the led does not light when the battery needed to be replaced.
Ibanez place 4.3V zener and 3.6K in series with the led to achieve the same effect.
From what i can make out the bottom line says "n523", so it could be a a1n5230 4.7V, or a 1n5231 5.1V, probably doesn't matter which really. Well spotted!
Edit: just took a look at the green monster thread, it's a 5.1V there.
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
Ready-to-print PDF-files:
SprintLayout6.0 file:
- Manfred
I am sorry, I had faults in the designators of the potentiometers.
Here are the corrected documents.
The PDF file for the solder side in the previous post was not affected. Ready-to-print PDF file: SprintLayout6.0 file:
- Manfred
- Gila_Crisis
Note that Deadend FX released a PCB for the Gomorrah, called Deuteronomy!
Their schematic is 100% proof. Krystal schem has few mistakes.
https://www.deadendfx.com/product/deuteronomy
- Manfred
I checked the circuit of Krystal by tracing the PCB.Gila_Crisis wrote: ↑15 May 2022, 17:21 Note that Deadend FX released a PCB for the Gomorrah, called Deuteronomy!
and found it to be correct.
Maybe Deadend FX has modified the circuit.
I will trace again to be sure
- karul
- Gila_Crisis
Check the 1M resistor going to Vr... the one on Q1 is connected to the Emitter, not the Base. Also the switch with the 2 condensators is different.
Did anybody test Krystal schematic and successfully built the pedal based on that?
- karul
There is a corrected schematic already, maybe you've missed it:Gila_Crisis wrote: ↑15 May 2022, 20:31 Check the 1M resistor going to Vr... the one on Q1 is connected to the Emitter, not the Base. Also the switch with the 2 condensators is different.
viewtopic.php?p=290683#p290683
- digi2t
- Degoop Doctor
While all the transistors are the same, I did some experimentation with different transistors when doing the validation build. I found that Q2 can really define the sub octave performance. In the end, I found that using a lower gain transistor in Q2 gave better performance in tracking and sound. I used PN2222A for all except Q2, where I used a 2N2219. YMMV.
Yeah I'd love to remove or replace that first schematic as it does contain mistakes, unfortunately i can't edit the post.karul wrote: ↑15 May 2022, 21:32There is a corrected schematic already, maybe you've missed it:Gila_Crisis wrote: ↑15 May 2022, 20:31 Check the 1M resistor going to Vr... the one on Q1 is connected to the Emitter, not the Base. Also the switch with the 2 condensators is different.
Great stuff Digi2t
- Manfred
The retracing of PCB layout gave me the same circuit structure as shown in the schematic, maybe anthing went wrong with the circuit design.
