Help with CE-2 build
matoni
Post by matoni »
Hello,
I need help with my CE-2 build. I bought the Cepheid Chorus board from Pedal PCB, so I am relatively sure that the problem is not a board problem. I am getting a signal coming through when I plug the pedal in, but there is no chorus sound. This is probably because of the R34 47K leak resistor seen at the very top of the schematic. There is no chorus sound, however. I have probed with an oscilloscope, so I know that there is a signal going into the MN3207 chip I am using, as well as voltage going in the correct pins, however, there is no signal coming out of pin 7 or 8. Please let me know what tests I can run to try and further diagnose the problem. I am using a corresponding MN3102 clock chip, but it may not be working. I have no clue how either the BBD or Clock chip work. Please let me know what I may have done wrong. I will post pictures if they are requested. Thanks so much in advance for your help.
Bolsyo
Has thanked: 37 times
Been thanked: 34 times
Post by Bolsyo »
Did you adjust the trim pot?
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
matoni wrote: 01 May 2022, 18:23 I have no clue how either the BBD or Clock chip work.
You got o-scope: probe BBD pins 2 and 6 looking for a clock...
