Daphon E20CH Chorus - pimp it!
Monkey95
Post by Monkey95 »
Hi
Newbie here
I have a Daphon E20CH Chorus pedal which came to me in a broken state, though was an easy fix, and now I'm wondering if I can give it some improvements to make it as quiet as possible and maximise its performance.
It's using the MN3207/MN3102 BBD pair, plus there's a MC4558 and 022D JRC (an 8-pin amp chip). There's 8-10 X C1815 transistors. Most of the caps are green polys - plus several cheap-brand electrolytics. The resistors all appear to be carbon film, the PCB is one-sided, and most of the components are crookedly placed with long or lop-sided legs. There's two trimpots [excuse ignorance I don't know what they're for]. But - the pedal does work!
I understand that the 3207/3102 chips are commonly used in Chorus pedals. Are there any mods I could do which would enhance this pedal or bring it closer to well-known Chorus designs that use those chips?
Jim
wildschwein
Post by wildschwein »
Pretty sure it's an Ibanez CS5 Soundtank under the hood. Maybe go digging for mods on that unit and verify if they can be applied. I found these links:
http://davidegironi.blogspot.com/2015/0 ... 5-mod.html
viewtopic.php?t=26168
https://marcuseffects.wordpress.com/201 ... horus-cs5/
Another post from this forum is here: viewtopic.php?t=6481
It was also sold in a plastic soundtank type shell as the E10CH and under a lot of other brand names:
https://www.effectsdatabase.com/model/daphon/e10/e10ch
