How important are buffers in high voltage tube pedals?
Reachahighernoon
Has thanked: 43 times
Been thanked: 11 times
Post by Reachahighernoon »
This is a weird thing I noticed, the Meatsmoke preamp has a buffer at the end of the circuit and a switch that allows attenuation of the output signal
While various Kingsley pedals for example doesnt seem to have one
On the Kingsley I dont see much of signal attenuation compared to the Meatsmoke, considering this is a high voltage tube pedal doesnt this make the output of the Kingsley too hot for most pedals after it?
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
Reachahighernoon wrote: 16 May 2022, 15:14 On the Kingsley I dont see much of signal attenuation
R11 with the volume pot are attenuating 10:1. Marginally usable output impedance, a buffer wouldn't hurt.
Reachahighernoon
FiveseveN wrote: 16 May 2022, 15:36
So R11 is the reason why the output isnt too hot, even at full volume?
FiveseveN
Post by FiveseveN »
Right.
