Way Huge Camel Toe Series/Parallel switch... has anyone figured out how it works?
The Rotagilla
Post by The Rotagilla »
I've been trying to figure out how Way Huge did the Series/Parallel toggle switch in the Camel Toe, either in the original or reissue. Has anyone traced that part of the circuit?
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
from the manual
Use the Drive Selector footswitch to toggle between the
two circuits, or flip the Series switch for a whole ’nother
sound: the Green Rhino OD and the Red Llama OD
combined in series. In Series mode, the Drive Selector
switch toggles the Red Llama OD on/off while the Green
Rhino OD is always active. The Camel Toe Triple Overdrive
MkII is an untamed beast! Handle with caution.
https://www.jimdunlop.com/content/manuals/WHE209.pdf
The Rotagilla
Thanks. Have all that but it isn't helping figure out the actual wiring.
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
See viewtopic.php?f=10&t=31426 for a possible solution.
karul
Post by karul »
"Parallel" label on the switch is misleading, two circuits never work in parallel, or to be more precise simultaneously. I guess, that label is appearing only on MKI, on MKII is omitted, and that's more accurate. If you want real parallel, you'll need different wiring.
Rotagilla, mauman's diagram is just fine, it will do the job.
With his diagram with master bypass you'll have
all three combinations just like in Camel toe.
fx1 on, fx2 off
fx1 off, fx2 on
fx1 on -> fx2 on (serial)
fx1 - rino, fx2 - lama
Here's another way with DPDT for serial/"parallel"
karul
Post by karul »
Also pay attention to where they've used shielded wires. Мauman's wiring method is better, inputs are grounded, it's less prone to troubles. More versatile too. Try it with DPTD, maybe it will be OK.
mauman
Post by mauman »
karul wrote: 23 May 2022, 14:30 Also pay attention to where they've used shielded wires.
+1 to karul on shielded wiring, I would think thru where the low-level input signals are coming near a high-level output signal. In this case, it's exactly where Way Huge used shielded wiring in the pics.
karul
Post by karul »
LAMA is the noisier circuit and they've used shielding in two different ways:
1) input wire between bypass & between serial sw. to lama's input (protecting low level input signals near lama)
2) between serial sw. to lama's input & between lama's output and selector sw. (combo)
karul
Post by karul »
One more variant of the wiring. If you don't want to have led for the bypass switch (just like they did it for camel toe), connect the grey wire from selector switch to the pin for the bypass.led instead directly to gnd. Also as an alternative to two led diodes for fx1 & fx2, one bi-color common anode can be used. To have led indicator for series/parallel switch 3pdt switch must be used.
