Attached a picture by R.G. Keen with a basic jFet switch as in boss/ibanez. If I am not mistaken when Vgs > V cuttoff the switch will be closed and if Vgs < V cuttoff it should be open. As an example
a J112 with V cuttoff between -1v en -5V
So if:
V control 9V, Vref 4,5V makes Vgs 9V-4,5V = 4,5V which is higher than V cuttoff -> Closed
V control = ground (0V), Vref 4,5V makes Vgs 0-4,5 = -4,5V which is in the Vcuttoff range -> Open
However... which ever jFet I try, when it is open it still bleeds signal between D/S. The louder the signal is (say humbucker with a full open OD) the more audible the (bleed) signal gets even at lower amp volumes. Why? How do I get to open the jfet/switch all the way and kill any S/D bleeding?
