Q.A. Rice, Guitar Note Expander, Electronics Today International, April 1981 🇦🇺
Posted: 26 Jun 2022, 14:49
by modman
PDF:
- 1979-4 Guitar Expander - Electronics Today International 4.jpg (61.52 KiB) Viewed 3343 times
Re: Q.A. Rice, Guitar Note Expander, Electronics Today International, April 1981
Posted: 26 Jun 2022, 16:08
by uncleboko
Why post these cheapo circuits from ETI, which at best were crap at the time???
Posted: 26 Jun 2022, 19:41
by modman
So everybody can see they are crap with their own eyes and need not obsess about it?
But you probably have a point.
Posted: 26 Jun 2022, 21:34
by CheapPedalCollector
There are sometimes interesting ideas that may not be executed well, that can be expanded on. Other times they are just bad and fun novelties. You can bet some booteeker is building them and selling them as the next magik boolet though.
Posted: 26 Jun 2022, 23:21
by Manfred
This post reminds me that I have this pedal slumbering in the depths of my collection, a reason to wake it up and get it running.
I am putting it in the queue for refurbishment.
Posted: 27 Jun 2022, 05:52
by cspar
I'm grateful that you post old magazine articles Modman. Thank you.
CheapPedalCollector wrote: ↑26 Jun 2022, 21:34
I've had a lot of fun and learned a lot while breadboarding old diy circuits regardless of if I ended up building them or not.
This one is pretty interesting. I don't remember ever seeing a compressor or an expander with a similar cmos topology.
Posted: 27 Jun 2022, 09:57
by Lani
cspar wrote: ↑27 Jun 2022, 05:52
I agree, keep em coming. Thanks Modman!!
Posted: 28 Jun 2022, 16:48
by deltafred
uncleboko wrote: ↑26 Jun 2022, 16:08
Yes they were crap at the time and they haven't improved with age but it is nice to see them again.
At that time I was in a job where half the time we were insanely busy, the rest we sitting around with virtually nothing to do. Our boss said that in case anyone important walked into the lab we should be always be looking busy and would fund small projects out of the department budget.
Most of the pedals that I built out of the Elektor, ETI, Practical Electronics, and Practical Wireless were so underwhelming that they never got boxed up and were immediately stripped for parts.
I did use a digital echo for quite some time that sounded like a ring modulator above the 12th fret because the sample frequency was not fast enough. Our rhythm guitarist used a treble booster for a while (I couldn't tell if it was on or bypassed but he seemed to like it so who was I to argue).
Posted: 30 Jun 2022, 16:13
by Manfred
I bought the used pedal in March 2018 and started to make the PCB clone for it, still missing the component values I will put in.
I forgot about it, first now through this topic I remembered.
Posted: 21 Jul 2022, 22:45
by Manfred
Here the finished PCB clone.
Next I will reassemble the pedal and make some measurements.
Ready-to-Print PDF-files:
SprintLayout6.0 file:
Posted: 27 Jul 2022, 02:39
by mictester
deltafred wrote: ↑28 Jun 2022, 16:48
There are several errors in the published circuit. My take on this circuit did away with the rotary switch, and had two options - compression or smoothly distorted compression (with remarkably little intermodulation distortion). The levels of the two modes were quite wildly different, so I had a switched compensation circuit, using a preset to equalise the levels. The CMOS IC used is somewhat vulnerable to static, so I built a buffering input interface....
When I built it, I expected it to be the usual let-down - a slightly unusual circuit, but nothing special....
It actually sounds great! What a surprise!
I'll see if I can find my modified version of this circuit, and I'll post it here.
Re: Q.A. Rice, Guitar Note Expander, Electronics Today International, April 1981 🇦🇺
Posted: 30 May 2023, 00:00
by mictester
Just stumbled across this thread. I remember the author of the article above - Quentin Rice worked in the same place as me at the time! My take on the circuit (which really wasn't all Quentin's work) was a simplified version without the rotary switch, but with two DPDT footswitches: Effect / Bypass and Compression / Overdrive. My prototype (which is around here somewhere) was built into a small diecast box, and had an internal jumper for single coil / humbucker. It sounded really good, and was recorded many times. I've built a few dozen of them over the years:
- Overdriving_Compressor_Sch.png (7.81 KiB) Viewed 418 times
The only further modification I'd do these days is to use a relay or even a 3-pole double throw footswitch for mode change to allow two "effect" controls to be selected too, allowing a better range of control in the two modes, and add a proper buffer stage to both the input and the output to isolate the CMOS from the outside world.
It's cheap enough to build, and it sounds pretty good.
Posted: 30 May 2023, 10:33
by Manfred
Interesting story!
Is the second MOS fet also a BS170?
Posted: 30 May 2023, 10:59
by cspar
Manfred wrote: ↑30 May 2023, 10:33
Looks to be the Q1 portion of the 4007ube. Mictester would know for sure though.
Posted: 31 May 2023, 07:00
by Manfred
cspar wrote: ↑30 May 2023, 10:59
You're right, if I had looked closely I could have seen that from the pin labels.
Posted: 02 Jun 2023, 01:22
by mictester
The finished versions of this circuit I've built lately have had additional transistor buffers on the way in and the way out. The 4007 is quite a sensitive beast, and easily killed by large voltage spikes. The transistor buffers ("emitter followers") completely eliminate the problems at very little cost. The buffers do not change the "sound" of the circuit at all. I'll sketch the additional bits later today and post them here.
