Help me find an alternative to 2SK772 for phaser.
masajinobe
my favorite amplifier: Fender '65 Twin Reverb
Post by masajinobe »
I can't find an alternative to the N-channel JFET 2SK772 :(
Yazoo55
Has thanked: 10 times
Been thanked: 19 times
Post by Yazoo55 »
Are these for a matched set of Fets? Which phaser model is it for?
masajinobe
Yazoo55 wrote: 02 Jul 2022, 23:22 Are these for a matched set of Fets? Which phaser model is it for?
Arion SPH-1
bow_and_error
Has thanked: 92 times
Been thanked: 41 times
Post by bow_and_error »
Saw this over on r/DIYPedals as well, but maybe somebody can add more clarity here about which Idss bin it uses:
Do you have any info on which Idss bin this pedal uses: 2SK772D, 2SK772E, or 2SK772F? If it's anything like the Arion SCH-1, then it's probably the F-variant (2SK772F).
Here are the specs for comparison:
  • 2SK772 - Vp: -0.3-2.5V, Idss: 1.2-12mA - F-variant is the high-Idss bin, so Idss = 5-12mA
  • 2SK184BL - Vp: -0.2-1.5V, Idss: 1.2-14mA - BL-variant is the high-Idss bin, so Idss = 5-12mA
  • 2N5952 - Vp: -1.3-3.5V, Idss: 4-8mA
  • Maybe: MPF4393 - Vp: -0.5-3V, Idss: 5-30mA (mine usually run Vp ~1.7V / Idss ~14mA)
This thread (use Google Translate) talks a bit about different versions of the phaser & other JFETs people have tried. If you can find them (they're obsolete & out of production), I'd go with either 2N5952 or 2SK184BL.
They will likely need to be matched pretty closely, so you'll have to buy more than 4 to get a decently matched quad. I included MPF4393 on that list as it's still in production & easy to find for cheap. If you're having trouble finding those older JFETs, you may want to buy 10-20 and give them a shot instead.
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
Small Bear has 2N5952 in quantity for $0.59 USD, https://smallbear-electronics.mybigcomm ... et-2n5952/ . They also have 2SK184 green and yellow, but not blue.
cspar
Has thanked: 68 times
Been thanked: 65 times
Post by cspar »
There is also this Arion SPH-1 thread with some mods and either schematic corrections/variations.
viewtopic.php?p=243186#p243186
"Just because the forgoing circuits have produced results there is no reason experimenting won't lead to added results." L. E. Darling, in his article containing the earliest published vacuum tube synthesizer circuit, Popular Science Jan 1920
uncleboko
Has thanked: 57 times
Been thanked: 38 times
Post by uncleboko »
Surely any reasonably close N FET will do the job, 2SK30 for instance, nothing special about the ciruitry.
