my Quad Preamp has suffered from being stored during near a decade... yes it's a shame
So of course I will have to change the electrolytics, all the orange drop capacitors which are on the anodes, and of course... the "vactrols"...
Some of them have died at power-on, when I tried to use the preamp after its long sleep in the closet.
Of course, I plan to "roll" my own 19 vactrols, seeing that the most important specs to target seems to be the R "off" which should be greater that 50Mohm to ensure proper insulations in the circuits, and slow speed to ensure popless switching (?).
If I'm right the 7812 regulator feeds the footswitch AND the 7805 regulator.
All the LEDs and TTLs are powered from this +5V rail; but the schematics show an +8V for the front panel LEDs. It seems wrong as on my unit those LEDs a directely connected to the 7805 output.
So most "vactrols" are driven by +5V / 360ohm; they clearly don't reach lower than 1K at R "on"; and the four (LDR21, 22, 23, 24) "LEAD1 and 2" + EQs vactrols seem to be "limited" to have a different range.
I don't understand why... could it cause oscillations if R"on" is lower, say less than 1K ?
or if R"off" is higher than 5Meg ?
The vactrols which switch the EQs and Channels are the slowers, the others have a slighty faster "release".
Time to release to dark resitance max is always a lot longer that Time to reach R"on" in full light.
Let me know if I'm wrong:
I will probably use GL5537-1 LDRs, they seem to reach more than 50Mohm at dark, they are slow enough to mimic the VTL5C4's "release".
But I think also about the GL5528 to mimic the VTL5C1, but this could be a lot too fast to reach R "on" max compared to a real old school opto.
The GL5516 are the slowest of this series, but the don't have a high R"off"; I measured an average 1-2Mohm for the "best" ones.
So really high dark resistance is harder to get than low light resistance!
Anyway modern LEDs will provide enough lumens at 10-12mA to reach a real low R"on" without a doubt.
It is strange to see that the LDRs are exposed to high voltages, way to high according to the datasheets.
The real VTLs are quoted to 100V max.
For sure all the LDRs would fry at power on if the main capacitors are dead...
Please, I have a doubt on a silver, DIP8 component, it takes place of a 555 according to the schematics, but its reference is unknown
I'm open to suggestions, to not forget to do something while the pcb will be reachable... I would prefer avoid to have to extract the pcb twice only because I forgot a pair of resistors, or a capacitor to replace.
Did someone already swap the originals VTL with a "hand rolled" one in a Mesa stuff?
