My friend asked me if I could take a look at his EHX Holy Grail which had been making weird noises.
I plugged it in and initially found the reverb wasn't working at all and I was only getting the clean signal, but no reverb.
I also noticed the 7805 regulator was really hot. Hot enough that I could only touch it for about 10s before it became uncomfortable.
Hot enough to have left a subtle brown coloring to the green PCB. So I thought this could be an issue maybe?
After opening it up I gave it a quick perfunctory clean with some IPA and tested, it had come back to life.
However the 7805 is still very hot. I don't know a ton about power regulators, I know (think?) that they work by dissipating energy as heat, but I'm just not sure how much is safe, don't want to damage the IC or anything. Also, if it does sound like it's in need of repair should I be looking to replace the regulator or be replacing the input and output caps or resistors?
I've attached the power schematic for reference.
