Regulator problems
kinski
Has thanked: 10 times
Post by kinski »
So I’m having a weird issue. I’ve used regulators countless times over the year to drop voltages to where I need them to be.
For a few years I’ve been using an 18v regulator with a 24v 4A power supply. Works beautifully. However, if I try to add a 9v regulator, the regulator over heats or goes up in smoke while the 18v regulator continues to remain stable and cool. Any ideas what could be happening here?
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
bigger the difference between input and output voltage, bigger the heat. 24-18=6V, 24-9=15V avoid using big differences between input and output voltage. do you use heatsinks? how much current you need to draw from 7809? take a good look at the datasheet.
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
Edit: Sorry Karul, you wrote the same facts just before me while I was still writing my post.
kinski wrote: 07 Aug 2022, 18:57 So I’m having a weird issue. I’ve used regulators countless times over the year to drop voltages to where I need them to be.
The differential voltage between output and input is 24 volts - 9 volts = 15V.
The power dissipation at the voltage regulator is calculated as 15 volts x load current.
I would say that the maximum power dissipation is exceeded in this case, the voltage regulator needs a suitable heat sink.
What type of voltage regulator is it, what is the load current.
kinski
Post by kinski »
Ah! Ok, I thought I was within spec for this. I had the regulator screwed against the enclosure. Figured that would be act fine as a heat sink and act as a ground. Could I power the 9v regulator with the 18v regulator?” That’s in the same enclosure?
Probably don’t need more than a couple hundred ma tops.
karul
Post by karul »
kinski wrote: 09 Aug 2022, 20:01Could I power the 9v regulator with the 18v regulator
yes, here is an example from Soundcraft Spirit Powerstation power supply, powered mixer designed by Douglas Self
