Seymour Duncan SFX-04 Twin Tube Mayhem  [traced]
jhergonz
my favorite amplifier: Mesa Boogie and Soldano SLO100
Has thanked: 110 times
Been thanked: 20 times
Post by jhergonz »
First of all, sorry for the bad grammar.
I had a Seymour Duncan SFX-04 Twin Tube Mayhem for repair, and the owner let me trace the pedal.
I didn't include the Power section, because I think it is the same from the SFX-03. Except for the power section of the ICs which is powered by regulated +/-12v.
I believe I traced the circuit properly, but feel free to recheck if you have the same unit with you.
Edit:
I forgot to include the path of the heater. +12v connected to pin six of V2, pin 3 of V2 connected to Pin 6 of V1, pin 3 of V1 to GND2
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi jhergonz,
Can you confirm the value of R8 connected at pin 5 and 7 of the second tube ?
jhergonz
Post by jhergonz »
ppluis0 wrote: 25 Aug 2022, 12:07 Hi jhergonz,
It should be 100k, my bad.
VivMeLol
Has thanked: 18 times
Been thanked: 23 times
Post by VivMeLol »
What do D1 and D2 do ?
ppluis0
Post by ppluis0 »
VivMeLol wrote: 26 Aug 2022, 17:27 What do D1 and D2 do ?
Hi VivMeLol,
Those diodes are to protect the input of U2.2 as the output signal of the second tube stage can be so high that damage that op amp.
jhergonz
Post by jhergonz »
Those are overvoltage protection for the opamps.
Tubes has high output that may cause damage to the opamps. That is why that opamps must be protected.
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
I made a rough math, R41 should be about 100kOhms and not 5.6kOhms.
I revised the schematic regarding the visibility.
I did not change the component values, that has time until all values are confirmed.
Manfred
Post by Manfred »
I ran a circuit simulation of the first stage.
I must take back my statement, am surprised the first stage also works with a collector resistance of 5.6 kiloohm, the stage gain is 5.
Manfred
Post by Manfred »
I ran a second circuit simulation of the entire semiconductor input stage with C27 in parallel with R2 as the load, the value of R41 was 5.6 Kiloohms.
I found the following gains depending on the value of VR1.1 at an input signal of 1 volt peak to peak @ 1 kHz.
VR1.1 = 0 Ohm -> gain ~6, VR1.1 = 250 Kiloohm -> gain ~44
ddpawel
my favorite amplifier: Marshall JCM800 2203
Been thanked: 12 times
Post by ddpawel »
Manfred wrote: 26 Aug 2022, 21:14 I made a rough math, R41 should be about 100kOhms and not 5.6kOhms.
C30 in mid control should be equal to 3.9nF. This will give mid frequency around 600Hz and Q around 2.5.
jhergonz
Post by jhergonz »
ddpawel wrote: 28 Aug 2022, 15:25
i send the unit back to the owner so I can't check.
ddpawel
Post by ddpawel »
jhergonz wrote: 28 Aug 2022, 17:58
You can't check, but we can calculate resonant frequencies f of gyrators.
For 39nF f is approximately equal to 1/(2 Pi sqrt(100000 Ohm * 2700 Ohm *(18 + 22)nF *(2.7 + 39)nF))~=237 Hz.
For 3.9nF f is approximately equal to=1/(2 Pi sqrt(100000 Ohm * 2700 Ohm *(18 + 22)nF *(2.7 + 3.9)nF))~=596 Hz.
Manfred
Post by Manfred »
There is an online calculator for:
http://tools.griffineffects.com/gyrator.php
Manfred
Post by Manfred »
In both tube stages the resistance values recommended in the table are applied, only the operating voltage is 150 volts here.
Are you sure with the specified 230 volts, because the power section was not included?
jhergonz
Post by jhergonz »
I measured it with my multi meter, it is somewhere around 230v, not exact but close.
I already sent the unit to the owner, so I can't measure it again.
But I didn't measure the resistor value with my multimeter, I just read the resistors' band.
I maybe wrong.
jhergonz
Post by jhergonz »
ddpawel wrote: 28 Aug 2022, 22:49
maybe you're right. 😁
