Keeley Rat mods
- tonymcbony
I had measured all these but my daughter in a fit of creativity drew pencil all over my original schematic – do these numbers check out?
Edit: R8 had a strange value, removed from schem
- Ichabod_Crane
Is R8 1.6k?
- tonymcbony
Apparently, according to initial scratchings.
That one and c7 seem a bit off
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
1.6k - NO
- bmxguitarsbmx
Is there a lot of clipping happening in the jet buffer? Biased as it is, it wouldn't have the most headroom. I must admit to only ever playing a Rat once.
I used to know a young "anarcho-communist" couple that worked at Proco in Kalamazoo. When they quit, they "liberated" a few thousand feet of instrument cable and all the connectors to make cables for the rest of time. It was weird because they always talked about how much they liked working there.
- tonymcbony
Would switching 10k to 1k increase overall output of the pedal, or just clip more?
- tonymcbony
So I’ve done the mods that are listed in that schem now (didn’t touch the erroneous 1M resistor ones but they’ve been edited out of schem now)
It’s got a lot more bass and a LOT more gain - it sounds better but loses the lower gain settings a bit.
Will be trying to tinker with the R4/C6 to trim it out a little
