Simple noise gate [documentation]
Hi there!
I am new here and I would like to share a noise gate circuit that I have been working on.
One or two years ago I was playing around with the MXR noise gate circuit and I did a lot of trial and error modifications to it.
Then I forgot about it, until a few weeks ago I rediscovered this project and finially finished it.
It is using only cheap and standard components (and not many of them) and it could easily be added to overdrive circuits or similar.
I am really sorry, if there already exist similar circuits posted by other users - my intention is not to copy someone else's work.
And I have to say that I am not schooled in electronic circit builds and stuff like that.
So there may be some flaws in the design (however, for me it is working without any issues).
Regarding the circuit, I guess you could also use a dual opamp to add a buffer to the "key" output. But for me it works perfectly as it is.
Of course you can also try different cap values for the decay: larger ones for longer, smaller ones for faster decay.
If you do not what to use it in the FX loop, but in front of the amp, just connect "Key_out" and "Sig_in" (and go from "Sig_out" to amp input).
I build it into a pedal and I am using it with my amp (Mesa Mark V:25) for several weeks now - at rehearsals and live shows.
For my personal (!) needs it works perfectly and I am super happy with it (in fact it replaced my Fortin Zuul).
Maybe some of you might find it helpful as well.
Matthes
Matthes
- CheapPedalCollector
Is the 3904 inverted, seems the emitter should go to ground.
- Ichabod_Crane
Wait a minute! This replaced your Fortin Zuul? Do you mean you prefer this to the Fortin Zuul?
I built the Fortin Zuul for a friend and, thought I can't compare it to any other noise gate, I tested it and I was totally amazed by it. I found it really really good: transparent, no decay of the note, I could even get feedback with it on. And if I bypassed distortion the Zuul doesn't make anything wrong with the clean sound.
It will be nice if this works so fine because it's a very simple circuit.
That is correct (even though the Zuul is a great pedal, without doubt).Ichabod_Crane wrote: ↑14 Sep 2022, 08:02 Wait a minute! This replaced your Fortin Zuul? Do you mean you prefer this to the Fortin Zuul?
First I used it instead of the Zuul just to test it in a real band situation.
But now I still have it in my setup because I am not missing anything with it.
Compared to its simplicity I am amazed how well it performs (at least for my needs).
But again, I am not trying to bash the Zuul, it's a great pedal.
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
I miss the reference potential for switching the JFET, is there a resistor between souce and ground?
- Ichabod_Crane
Is the KEY OUT optional or essential to makes it working?
(I tried to drawn a veroboard layout. Do someone want to see it?)
- bmxguitarsbmx
The Key input/output allows the muting to happen in the effects loop, so that it silences the most noise. But, the sensing of signal/noise happens at the Key Input as it has the least processing and cleanest signal to trigger a gate.
The mute jFet is ground referenced through the "KEY OUT" ground connection, which then would be connected to the send and return grounds of the amplifiers effects loop (or through the input and output of your distortion box). Doing it this way prevents ground loops. The mute Jfet does need to be ground referenced to work, as Manfred points out. Switching jacks could be used to pass the input from the "KEY IN" to the "SIG IN" jack when not trying to key an amp or distortion box, like Ichabod is proposing.
- bmxguitarsbmx
This 2n3904 is still blowing my mind. It is setup like a diode/level shifter sort of deal. Anyone care to explain it or link reference?
- Manfred
In the schematic a N-Channel FET symbol is drawn but the J175 is a P-Channel type.
- Manfred
I ran a simualation from C4 parallel to R5, there a sine signal was fed.bmxguitarsbmx wrote: ↑19 Sep 2022, 15:46 This 2n3904 is still blowing my mind. It is setup like a diode/level shifter sort of deal. Anyone care to explain it or link reference?
At the emitter of the 2N3904 still about half the AC level comes out,
but the peak of the sine wave always cuts the 0 volt line and is completely in the negative range.
There is no DC voltage generated that could drive a JFET, I also wonder how that works.
Hey guys, appologies for the delay!
As stated in my opening post, I am not educated in electronics or circuit design.
The basic circuit came out by chance and I optimized it by trial-and-error changing component values.
All I can say that it works for me - I breadboarded (daes that verb exist?) and build it exactly as shown in the shematic.
After reading your comments, I breadborded it again to ensure I did not miss anything: It still works, as my previous build.
Maybe someone can simply replicate it on a breadboard?
It is really not hard to build and all components are easy to get.
It would be super cool, if someone who is actually skilled in these things could help to improve it.
(if it helps I could also take some pictures or even record a short video, but that would need to wait until next week)
Cherrs,
Matthes
Cherrs,
Matthes
- Manfred
Hi Matthes,
did you use the J175 type?
Yes, it is a J175 transistor.
And I was able to record a short video, just to show that the gate it is working.
I do not have my real amp with me, but I do have an AXE FX 3 that I used instead:
I used its "OUT 4" and "IN 4" to simulate an actual FX loop.
Of course all internal noise gates are turned off and I used a ridiculous amout of gain, just for demo purpose.
I try to add some pictures of the breadboard asap, so you can see all details to compare with my schematic.
Here the link to the video: https://drive.google.com/file/d/1O7tniAWsO3YppKD-ipCSJw83VAKCKpzx/view?usp=sharing
- bmxguitarsbmx
Did you mess with the 250k threshold control? It may be acting as a voltage divider with the string of R7, R6, R5 to ground to turn the J175 off. Then, when signal is present the 2n3904 is rectifying it in the right way to turn the J175 on...Manfred wrote: ↑19 Sep 2022, 16:36I ran a simualation from C4 parallel to R5, there a sine signal was fed.bmxguitarsbmx wrote: ↑19 Sep 2022, 15:46 This 2n3904 is still blowing my mind. It is setup like a diode/level shifter sort of deal. Anyone care to explain it or link reference?
I really don't know. I tried swapping the 2n3904 for diodes and it killed the functionality. At least in the way I tried it.
It does work! I breadboarded it. Great job Matthes! I love a good mystery, especially when it works this well.
Thank you so much!bmxguitarsbmx wrote: ↑20 Sep 2022, 17:15 It does work! I breadboarded it. Great job Matthes! I love a good mystery, especially when it works this well.
I wish I knew more about all the theory behind it.
So it is super interesting for me to read the comments by you guys who actually have the knowledge.
I already did some more builds: a modified SD1 overdrive, a remote switchable 3-band EQ, a 2nd order LP/HP filter pedal, ...
But I never really understood in detail what is going on (even though I do have some deeper knowledge in audio DSP).
I just kept tweeking until I got the results I was looking for.
Now I really want to get a better understanding of this stuff... It just makes the life of a passionate guitar player so much easier!
- EddieTavares
Hi
A friend of me did a similar circuit without jfet using a bjt transistor to shunt the signal to the ground, it is a very suitable add on to any high gain distortion circuit:
- bmxguitarsbmx
Yeah, well hopefully we don't have to wait around too long for someone smart enough to explain why the 3904 works as is... I'm a total noob in the DSP realm, so hopefully I can make something this good one of these days ;PMatthes wrote: ↑20 Sep 2022, 17:46Thank you so much!bmxguitarsbmx wrote: ↑20 Sep 2022, 17:15 It does work! I breadboarded it. Great job Matthes! I love a good mystery, especially when it works this well.
- Manfred
Yes, I ran the first Simulation, with the 250k threshold control.Did you mess with the 250k threshold control? It may be acting as a voltage divider with the string of R7, R6, R5 to ground to turn the J175 off. Then, when signal is present the 2n3904 is rectifying it in the right way to turn the J175 on...
I ran a new simulation with a threshold potentiometer setting of 50% and a sine wave input voltage of 3Vpp fed to the junction of C3, C4 and R5.but the peak of the sine wave always cuts the 0 volt line and is completely in the negative range.
There I have to correct my statement in the post above.
Even if you do not see the generated DC voltage directly, it is the average value of the AC voltage completely shifted below the zero lines. I create a PCB according the schematic above. Ready-to-Print files: Sprint-Layout6.0 file: Gerber files:
- rcustoms
can work with any P-channel silicon field-effect transistors?
