DOD Carcosa issue
CheapPedalCollector
Has thanked: 432 times
Been thanked: 141 times
Post by CheapPedalCollector »
I bought a broken Carcosa thinking it was through hole, but it's not other than the pots and DC jack. The Before control seems broken and sounds like it has a bad cap passing DC, its very scratchy and the pedal doesn't sound anything like any of the demos I've heard. Could anyone possibly take some voltage measurements so I could try to locate the bad part?
Alternatively, anyone know where in the US I can send it for professional repair?
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi Collector,
I found in the pedalPCB site that there are a project identical to the unit you have:
https://docs.pedalpcb.com/project/Carcass-PedalPCB.pdf
Perhaps this schematic helps you to pinpoint the faulty component.
CheapPedalCollector
Thanks,
I actually figured out what was wrong with it. I took it back apart and tested it outside the case, and it worked fine so I was stumped. Turns out there was a small metal shaving floating around in the case that was shorting something out or had gotten into the potentiometer.
After removing it, it works great now and I really really like it.
