Ramble FX Twin Bender question
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
Hello
I know this is a Tone Bender circuit, but does anyone know what they are doing to create the impede control? Or what they did for the mids/stock/fat switch?
Rob
Modify message
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
https://www.ramblefx.com/twin-bender
THREE-WAY EQ SWITCH
The Tone Bender circuit doesn't adapt well to a tone knob. This switch swaps out capacitors in order to get three different voicings while preserving the stock circuit.
https://www.ramblefx.com/_files/ugd/cd9 ... 365a14.pdf
IMPEDE (MINI-KNOB).
This changes the impedance by adding resistance at the input. Fully clockwise is no resistance, the stock Tone Bender setting. Turn this counter-clockwise to help restore tone if Twin Bender is placed after a buffer, or to restore a wah's tone if placed after a wah. It also has a large effect on gain and tone
https://www.ramblefx.com/fuzz-tips
Some people use an external buffer with a bypass loop pedal to handle the switching. Some use a circuit called a pickup simulator. Sometimes it just takes some resistance between the pedals to restore the wah. With the current version Twin Bender, simply turn the 'IMPEDE' mini-knob to restore good tone.
karul
Post by karul »
caspercody
Thanks, but looking for schematic’s showing how they might have done this.
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
Mid/Stock/Fat is probably switching the input cap to add low end. Center position is stock cap only, Mid adds another cap in parallel, Fat adds a larger cap in parallel. Impede pot is 100kB and sits at the input, maybe in series with the 100k from Q1 base to ground?
karul
Post by karul »
"impede knob" (100k LIN, value mentioned in GBE video) - 50k knob in fulltone 69 ?
as mouman suggested, good candidate for tone switch is the input cap
fulltone 69
fulltone 69
tone bender mk2
tone bender mk2
tone bender mk1.5
tone bender mk1.5
karul
Post by karul »
some gutshots, different layout
https://murakawavn.exblog.jp/21840750/
