- A pre-drilled CNC Pro 125B aluminum enclosure from lovemyswitches.com. You don't have to worry about exacting tolerances or accurately drilling in the top of the enclosure. All done. It’s ready to paint or customize any way you see fit. You will need to drill your own holes for your pedal’s potentiometers and toggle switches, but the audio jack, DC power, footswitch, and LED holes are already drilled for you.
- PCB “daughterboard” for the audio I/O and DC power jack with support for reverse-polarity protection
- PCB daughterboard for the footswitch, LED, and additional power filtering capacitor
- 4-wire ribbon cable to connect the daughterboards
- 2 Neutrik NRJ6HM-1 PCB mount 1/4″ mono audio jacks with dress nuts
- Kobiconn 7620-E DC power jack
- Premium feather-soft click 3PDT footswitch from lovemyswitches.com (these are awesome!)
- 4k7 Royal Ohm metal film resistor (current limiting resistor for the LED)
- 3mm diffused red LED
- 1N5817 diode for polarity protection
- TDK 0.1uF MLCC capacitor with C0G dielectric
More info at http://clevelandmusicco.com/pedal-kits-pcbs/. The kit is currently for sale at https://reverb.com/item/62628305-diy-pe ... d-your-pcb.
Disclosure: I am the guy behind Cleveland Music Co. This is totally a promotional post, but it's not just to drum up sales; I'd also welcome any feedback on the idea in general. Stupid idea? Say so. Could use some improvements to make it more useful to the community? Say that too. All thoughts welcome.
Cheers!
<edit: deleted some exclamation points. far too exciting for this forum
