Where can I find a PCB layout for a voltage doubler?
jimosity
Post by jimosity »
I'd like to build a voltage doubler that will allow me to run my Crunch Box at 18 volts instead of 9.
Are there any good schematics / pcbs / layouts that will give me 18v out of a 9v power supply?
I've tried searching and I find skeptical results...one says it's really only putting out 15 volts and the others are so old of posts that I wonder how relevant they are.
Thanks guys.
TragicTravisty
Post by TragicTravisty »
well you can run it up to 25 volts, why not do that?
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
https://www.freestompboxes.org/download/ ... id=774&t=1
go to mutron c200 wah vol....it is good and working :block:
alteredsounds
Post by alteredsounds »
You can pretty much just copy the bottom left side of the Sagiterius (bad spelling! mini-klon) pcb. That's essentially the charge pump section (chip, caps, 1n4001 diodes and a protection diode.)
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
RLBJR65
Post by RLBJR65 »
jimosity
Post by jimosity »
Thanks for the links guys, I'll test one or two of these ideas.
Jim
You can always use such a small circuit to have a go on the DIY Layout Creator.
Some more links that were not posted yet.
Analogguru's Split Supply with a 555
18V from a MAX1044 by Soulsonic
Voltage Double circuit with a MAX1044 on Geofex
