Stafford Maxon Hizbender 1944T
Pedal was only released in Japan, and seems like only from 2011-2012.
Name suggests a tonebender, anything but.
Basically a distortion+ with input/output buffers. Standard Maxon JFET switching.
schem1.pdf- (17.22 KiB) Downloaded 77 times
- CheapPedalCollector
Kind of a cross between a sonic distortion sans tone control and a distortion +. It'll be brighter than a distortion + by quite a lot with the input .001 omitted and the 1.8K resistor rather than 10k. It'll have more distortion too. Too bad it's a 50k volume pot instead of 100k, the output will be weak, that would be the first mod I did to it.
- FiveseveN
How do you figure? The difference is 0.01 dB.
- FiveseveN
By reading books on electronics.
This circuit doesn't have the BMP-style tone control with its 10 dB insertion loss and significant voltage division with the load (the volume pot). I.e. a 100 K pot won't do shit in these very different circumstances.
Germanium diodes sure don't help if volume is an issue but it's hardly the only pedal to use this configuration.
Try it.
- mirosol
Drew a vero layout with slightly unusual board dimensions. Using just a half of dual opamp is a bit of a pain to draw. In this regard, circuit reminds me of SD-9 Sonic Distortion which also had one half unused and unterminated. Personally i think unused half should be terminated properly instead of letting it float.. In these designs however, it may not mattter all that much.
Unverified. At the time of writing.
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
