Soldano SLO Super Lead Overdrive Pedal
Nicale19
Post by Nicale19 »
Smd circuit.. Recently tried, the feeling is that it has a poor Dynamics.
I hope I'm wrong otherwise I'll make it back
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
Nicale19 wrote: 21 Nov 2022, 15:37 Digital circuit.
:scratch: I don't see any DSP but there's plenty of op amps and passives to make a distortion.
plush
Has thanked: 35 times
Been thanked: 160 times
Post by plush »
Digital circuit.
Nah, it's fully analog. The only thing digital is this little MCU that controls relay and is not present in signal line.
Also, yes, it is a little flobby, nothing compared to original soldano preamps, which are way tighter. Maybe it could benefit from a mod, reducing some bass on a certain stage.
Nicale19
Post by Nicale19 »
FiveseveN wrote: 21 Nov 2022, 15:50
Yes sorry I expressed myself badly. I meant smd.
In any case it is a simple scheme Seemingly
Nicale19
Post by Nicale19 »
plush wrote: 21 Nov 2022, 16:43
Digital circuit.
How modding this thing?? 😅😅
plush
Post by plush »
Nicale19 wrote: 22 Nov 2022, 03:53
Digital circuit.
You trace, you calc, you mod.
Saruman
Been thanked: 145 times
Post by Saruman »
In all the demo videos, this pedal has a very bad sound, especially when it is compared to the SLO-100. For example, I am not interested in drawing a diagram from this device. Here with the Orginal Effects Revival Drive I would draw a schematic. This pedal is a failure of Soldano.
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
Saruman wrote: 22 Nov 2022, 16:43 In all the demo videos, this pedal has a very bad sound, especially when it is compared to the SLO-100. For example, I am not interested in drawing a diagram from this device. Here with the Orginal Effects Revival Drive I would draw a schematic. This pedal is a failure of Soldano.
Michael Soldano sold his brand to BAD
plush
Post by plush »
bmxguitarsbmx wrote: 22 Nov 2022, 21:03
AFAIK, he's still head designer, so nothing has changed besides the money flow.
bmxguitarsbmx
plush wrote: 23 Nov 2022, 15:06
Maybe in the promotional material. Have you seen gutshots and the schematic for the new SLO? It's a different paradigm. I think Michael is doing what he said he wanted to do- other things.
plush
Post by plush »
bmxguitarsbmx wrote: 23 Nov 2022, 19:30 Have you seen gutshots and the schematic for the new SLO?
Got new schematic to compare? :wink:
bmxguitarsbmx
Slo100 MK2 DRAFT
errors in power supply as well. so, dont build!
Draft there are errors and channel switching may pop as is.  Important stuff is there.
Has thanked: 218 times
Been thanked: 857 times
Great work so far BMX!
FuzzMonkey
Has thanked: 43 times
Been thanked: 26 times
Post by FuzzMonkey »
I'm sure a schematic of the pedal will pop up online soon.
ct88
Been thanked: 9 times
Post by ct88 »
Seems like the same 3ics model + 7660s used by Diezel to shape Vh4 preamp
Very curious about the cold clipper implementation thou :)
