ZON bass preamp  [schematic]
Yun_Suki
my favorite amplifier: Boss Katana Ⅱ
Completed builds: hummmmm.....
Has thanked: 50 times
Been thanked: 42 times
Post by Yun_Suki »
I don't remember which one...
But...however, I have made a copy that works fine.
The progress of the reverse engineering will be updated again after a while...
darmstat
Been thanked: 54 times
Post by darmstat »
Is there a schematic?
george giblet
Has thanked: 180 times
Been thanked: 272 times
Post by george giblet »
The preamp is the one with the Magnetic + Piezo pickups (ZP-3).
Any chance to get the cap values and pot values?
I've traced 99.9% of the schematic but there are very few caps values and no pot values.
Yun_Suki
Post by Yun_Suki »
This is the value of the component as well as the model number.
ZON 贝斯内置主动电路_2022-12-20.pdf
(231.83 KiB) Downloaded 92 times
ZON-pre-BOM.txt
(859 Bytes) Downloaded 45 times
Yun_Suki
Post by Yun_Suki »
george giblet wrote: 20 Dec 2022, 00:16 The preamp is the one with the Magnetic + Piezo pickups (ZP-3).
Hi,All potentiometers and trim potentiometers are 100KΩ
george giblet
Thanks a lot for all that detailed information.
Awesome, stuff!
The schematic appears below. I've tried to match the part designators on the your PCB.
I've also added the EQ curves.
It is interesting how much the Mid switch frequency affects the bass control even though
the mid control is set flat.
The treble controls are not symmetric, there is more cut than boost.
The 100k's on the first stage of the magnetic preamp and the 470k/220k's on the
second stage are going to be adding a lot of noise. I suspect replacing
the second stage with a non-inverting amplifier like U3b would lower the noise.
The circuit and parts values are very similar to the National Semiconductors
applications notes and datasheets! (11k, 3k6, 100k pot)
george giblet
FYI, here's a pic of a 4-string (Zon Legacy Elite 4). You can see how the Piezo is wired.
Yun_Suki
Post by Yun_Suki »
george giblet wrote: 20 Dec 2022, 23:26 Thanks a lot for all that detailed information.
Awesome, stuff!
Wow, very detailed! Thank you for your contribution to the forum! (a Big Hug~)
george giblet
No problem. Thank you for all your efforts.
george giblet
I've managed to trace the ZP-2 as well.
Unfortunately this tracing doesn't have the accuracy of the ZP-3 schematic.
As far as I know, the ZP-x preamps are the polyfusion preamps and the ZB-x preamps
are the Bartolini preamps.
Yun_Suki
Post by Yun_Suki »
george giblet wrote: 21 Dec 2022, 10:50 I've managed to trace the ZP-2 as well.
I've also got this board from a friend before.
But unfortunately, I lost it before I could collect the component values of the capacitor...
These are the photos that my friend provided me:
george giblet
Thanks for the new pics. They were very useful.
Since the one of the pots is removed I could confirmed the circuit around C5 and R7.
I also made a better guess of the circuit around U1a - still not confident it is correct.
Added better guesses for the tone control caps.
I updated the ZP-2 schematic in the previous post to version 1.1
george giblet
OK I've updated the ZP-2 schematic to V1.2
- fixed one error on U1a
- added more notes
- added trace info for older Rev A PCB
ZP-2 Rev A PCB (1995):
