More gut shots of the Ojai here: https://alfalfasprout69.wixsite.com/oja ... t-pictures
24V connector is EIAJ-05 (https://www.strymon.net/faq/link-ojai-units-zuma/)
24V input/loop board appears to just hold a Nichicon filter cap & (common mode, given 2 colours of wire?) inductor.
16 pin chip marked "AJE BAC" is probably a buck converter. Possibly controller only? Figuring out what this is should lead to a datasheet explaining 90% of the rest of it.
3 pin SOT connected to the 16 pin chip probably a power transistor. Single-ended drive?
Transformer marked Chipsen EP10 (28uH) TAIHU130-tm
large body 4 pin on back side of the board probably an opto isolator
not sure what the 5 pin SOT package next to it could be. Looks like it is on the output side of the transformer.
