PCB is standard for series 2 Exars - single-sided, visible in the light.
Before tracing, I played with the pedal, whose active EQ was hard to dial for good tones but possible. My initial thought was that it has active parametric EQ, but later it appeared that it is not
So the effect structure is the following: FET buffer, BJT gain stage, op-amp gain stage, and diodes clipping. A pretty similar arrangement for Boss DS-1, with differences in values. However, diodes seem to go through a 10uF cap which is a bit strange, but I double-checked that. Then it comes to the most exciting part of the circuit - EQ, which I haven't seen in any pedal before. After the diodes clipping signal goes through the op-amp buffer/splitter. One half is a Big Muff tone stack with a boost stage placed after; another half is a kind of an active bandpass filter; both are controlled by dual Frequency pot and share the same values. Equalize pot acts as a mixer of both halves.
I made a SPICE simulation in CircuitLab https://www.circuitlab.com/circuit/ymr6 ... uper-fuzz/ to check where I traced everything correctly, and it looks like it works. Fascinating EQ circuit good platform for mods IMO. With some modifications, I would try to use it with other fuzz/distortion circuits.
Attached is the schematic with buffered bypass switching omitted.
