I built Diaz Texas Ranger clone with silicone transistor. It sounds fine until you max the guitar volume pot - then it sounds very farty. The voltage on the collector is 8v with the 68 k resistor. I tried swapping transistors and increasing value of 68k resistor but when it's 100k and voltage at collector is around 7v I still get that farty sound. Anyone knows is it normal or what should be voltage on the collector in this circuit? I suggested myself with Rangemaster bias voltage that should sit in between 6.8-7v. Transistors i used were between 100-300 hfe. Any help appreciated
