Visualsound - H2O chorus / delay
- Bernardduur
Hi all!
I got one in with a broken delay knob. Pics are on my instagram page (see sig)
I only traced the schematic that I found interesting.
- The Delay part is a copy of the Danelectro Dan-Echo with a PT2395 IC w/ some mods
- The Chorus part is a copy of the Ibanez SC10 pedal w/ some mods
EnjoY!
EnjoY!
- dmc777
Thanks for this. Wonder how much difference there is between this and the single visual sound liquid chorus v2? It has speed, width, delay time and depth knobs. What exactly is the difference in width and depth? In stereo, the width seems to widen the spread or just make it thicker.
- dmc777
Also, what can be changed to give the chorus the EHX mistress and small clone “metallic” or “liquidy” tone? More high end? I’m sure you’re aware of the sound I’m talking about. I’ve always wondered this.
- CheapPedalCollector
I have one too, the taper on some of the pots is a bit weird as well. The echo mix should be audio I think, probably a good mod for it.
Also the link in your sig doesn't work.
- dmc777
Damn it I thought the new post was a response to my questions lol.CheapPedalCollector wrote: ↑09 Jan 2023, 18:48 I have one too, the taper on some of the pots is a bit weird as well. The echo mix should be audio I think, probably a good mod for it.
- mauman
I did a calibration for another builder on a Madbean Current Lover, which pretty much an EHX Electric Mistress. To my ear it had tons of high end, probably due to less lowpass filtering. Here's the schematic for reference if you want to compare the filtering.
- dmc777
I’ll have to pull up the small clone schematic and compare it. There’s alot going on in that current lover. Looks like a lot of changes from the original mistress. Appreciate it though.
- dmc777
