Hi, got a pressure tank, took it apart and got some pics :3. It's actually very close to the diamond comp minus the tone bypass, even down to the double coupling caps which is kinda pointless in this mlcc version but still cute. Our unit's frequency response is not very flat, especially at higher "comp" settings, which is no surprise with the LM358 (0.6uV/s slew) that works as the makeup gain amplifier (U1) in this unit. We swapped it for a TL072, and while the bandwidth still feels limited at least the dullness at high compression is gone. The phase inverter is a TL062 btw, nothing wrong with that as far as we can tell.
R26 sets the max LED current and thereby ratio, you can add parallel resistors to make it more squishy, but you might wanna increase the envelope cap C20 proportionally-ish to avoid low frequency ripple.
