Help understanding toggle switches??? Custom pickup switching.
AaronW
Post by AaronW »
I’m planning a guitar build and trying to figure out the electronics wiring. I don’t fully understand switches, whether to us a DPDT or a 3PDT on/on/on.
Here is what I’m wanting to do:
HSH pickup configuration. 3-way blade pickup selector, wired Neck, Neck/Bridge, Bridge.
Then a separate mini-toggle: up - middle pickup only (shuts neck & bridge off). Middle - uses only the 3 way blade, for just neck/bridge options. Down - middle brought in with the neck/bridge.
I have an idea how this may be done with a on/off/on 3PDT toggle. But I’ll have to wire it up and see if it works. If someone wants to help with a layout, that’d be great. BUT, I’d much rather be pointed to a resource so I can learn about switches and how to wire this, and future ideas.
Any suggestions? Thanks!
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
Would you be willing to settle for middle+others in the Center position of the mini-toggle (instead of Down)? That would simplify it a lot: you'd only need a three-position SPDT normally-closed switch, the Les Paul type. Or any other functionally compatible type like your blade. It would be a traditional 3-way switch in series with another.
AaronW
Post by AaronW »
FiveseveN wrote: 26 Jan 2023, 19:57 Would you be willing to settle for middle+others in the Center position of the mini-toggle (instead of Down)? That would simplify it a lot: you'd only need a three-position SPDT normally-closed switch, the Les Paul type. Or any other functionally compatible type like your blade. It would be a traditional 3-way switch in series with another.
Yeah middle works fine, then up or down for middle only and only bridge/neck pickups.
The G
Grease Monkey
Has thanked: 407 times
Been thanked: 282 times
Post by The G »
I counted 5 positions, so you could get all of them with a single regular (5PDT, 5-poles/double-throw) 5-way guitar switch. You didn't mention if your humbuckers are splittable or if you want to connect them in series or parallel - the technicalities depend on details.
For wiring documentation I like the Schaller site, i.e. https://schaller.info/en/hsh for HSH wirings.
