The Beatles Pedal
CheapPedalCollector
Has thanked: 432 times
Been thanked: 141 times
Post by CheapPedalCollector »
What is this pedal trying to achieve?
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
CheapPedalCollector wrote: 13 Feb 2023, 06:32 What is this pedal trying to achieve?
Sales! :lol:
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
deltafred wrote: 13 Feb 2023, 09:28
Sales! :lol:
Exactly. And maximum return of minimal investment 🤣
CheapPedalCollector
Hah!
blackcorvo
my favorite amplifier: Vox Pathfinder 10
Completed builds: • Honeytube (Danelectro Honeytone tube conversion);
• M014 (self-split push-pull 6P14P amp);
• Vox Pathfinder 10 (soft clip & top boost mods);
Been thanked: 21 times
Post by blackcorvo »
Are you sure it's not a circuit inspired by the tube sound overdrive?
https://nexp.pt/arsenio.html
Could explain the two transistors.
blackcorvo.com
She/they as of August 2021
deltafred
Post by deltafred »
blackcorvo wrote: 02 Mar 2023, 04:33 Are you sure it's not a circuit inspired by the tube sound overdrive?
That would make a lot more sense as it would give more of the pushed valve (tube) amp sound.
pilau
Post by pilau »
Thank you all for pitching in! I've been a bit busy with work etc. but I'm back. Following up on everything.
Trying to recreate the sound of Vox UL730 and Vox Conqueror, or in other words, sound like the Beatles
That looks quite suspiciously similar! Will definitely use it as a reference. Thanks!
What are VM1, VM2, VG1 and V19 in this circuit?
What is the function of this 100ohm resistor? (marked in orange) Link to picture of full PCB for context
andy-h-h
Has thanked: 20 times
Been thanked: 39 times
Post by andy-h-h »
Check the schematic that grrunge posted on the previous page. The 100ohm resistor forms part of the standard power filtering and protection system, along with the 1N400X diode, ceramic (100n?) & electrolytic capacitor (probably 100u at a guess)
pilau
Post by pilau »
andy-h-h wrote: 06 Mar 2023, 20:20 Check the schematic that grrunge posted on the previous page. The 100ohm resistor forms part of the standard power filtering and protection system, along with the 1N400X diode, ceramic (100n?) & electrolytic capacitor (probably 100u at a guess)
Thank you very much, but can you explain exactly how it functions as part of the power filtering and protection system? What is its purpose?
grrrunge
Post by grrrunge »
It's a passive first-order low-pass filter with a corner frequency of 1/(2*pi*R*C)
Look up passive RC filters for more info 🥳
pilau
Post by pilau »
grrrunge wrote: 07 Mar 2023, 04:47 It's a passive first-order low-pass filter with a corner frequency of 1/(2*pi*R*C)
Thanks grrrunge, I didn't realize it was just an RC filter. Thought there was more to it!
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
Voltage Meter 1 and 2, Voltage Generator 1 and Voltage (Generator) 1 (the sequel): 9 volts. They are required to compute the transient simulation in the insert. Look for TINA-TI or SPICE in general to learn about circuit simulation.
pilau
Post by pilau »
FiveseveN wrote: 07 Mar 2023, 14:04 Voltage Meter 1 and 2, Voltage Generator 1 and Voltage (Generator) 1 (the sequel): 9 volts. They are required to compute the transient simulation in the insert. Look for TINA-TI or SPICE in general to learn about circuit simulation.
Thanks, that helps! I see now that these volt meters are used to plot the scope to the right of the circuit. I definitely want to try simulating this circuit with LiveSpice.
grrrunge wrote: 05 Feb 2023, 20:57 IMG_20230205_214421.jpg
This is probably a good starting point for experimentation.
So I started working out your suggestion (thanks again for taking the time to make it). I'm focusing first on the reverse polarity protection and power supply decoupling:
I was trying to compare that circuit with the rest of the information and make out what the traces could look like on the back of the PCB. If I got you right, grrrunge, this is what you're suggesting? (The dashed line avoids obscuring the image. Excuse the crudeness, I made it on my phone)
