Don't Tell Ray: A PT2399-Based Oil Can-Style Delay  [documentation]
Ripthorn
Been thanked: 113 times
Post by Ripthorn »
Hi all, this project was one that I wanted to do for a while. It's been pretty fun digging into how oil can delays work and sound. Don't Tell Ray has a front end that can get gritty and dirty, a sinusoidal LFO, modulation speeds that match the hardware, and a tone control that allows the delays to stay nice and clean or dark and mellow. I have a full rundown of how the circuit works on my page about it here: https://scientificguitarist.wixsite.com ... t-tell-ray. Here is the demo:
Exact Science is Not an Exact Science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
Frank_NH
Has thanked: 99 times
Been thanked: 144 times
Post by Frank_NH »
Excellent design - thanks for sharing! I especially like the Grit control to add some hair to the delay tone. I could see this being the only pedal I’d need for rockabilly and country.
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
Nice work Rip! Sounds real good
Frank_NH
Post by Frank_NH »
As mentioned in the other forum, I noticed some “crackle” when you turned the Grit pot in the demo. I think a 1u capacitor at the output of the first op amp should fix it without changing the tone.
I may eventually have a go with this on my breadboard. I overbought some PT2399 chips and so have bunch to use up.
Ripthorn
Post by Ripthorn »
Thanks, guys! Yeah, the crackle on the grit control is because the signal goes to ground instead of Vref and there is not output cap from opamp stage. Fixing either of those two would eliminate that issue.
