TDA 2822 practice amp advice
Posted: 06 Feb 2023, 20:15
I'm trying to build a practice amp using an 8 Ohm speaker and a TDA 2822 IC that will run on 9v pedal power.
For a first attempt, I built the bridged example from the datasheet, shown here:
It works, and it's a bit more volume than the usual LM386 amps I've built (ruby, noisy cricket, etc), but zooks its dirty. Like fuzz dirty. If I crank WAY back on the input volume it cleans up OK, but I'm just wondering if I can do anything to make that sample circuit play nicer while still getting volume. Has anyone used this chip in an amp? Is this just the limitation of a single-supply 9v circuit?
