Korg - Pitchblack Tuner
- Contact:
I love my Pitchblack.... it's the easiest thing on my pedal board! Huge, easy to read and understand display. Built like a tank. I think it's the only stomp accurate within 1c too!
- soulsonic
Uses a relay for bypass? That's pretty slick. Can it be recalibrated down to 432Hz... maybe even 424Hz?
- seniorLoco
436--445 Hz (1 Hz steps)
- soulsonic
NO 432?!
Sorry, I could never purchase this tuner. I guess I have to save up for the Peterson.
- Bernardduur
Why this calibration (I'm just curious as most tuners have em but I never use anything other then 440)?
Edit; I just typed 432 in Google and got a lot of links
Is it really that "special"??????
- tuemmueh
Fuzzer wrote:http://www.432hz.org/
btw, this is fantastic:
Take a Tast of 432Hz Water. Simply hold the 432Hz tuningfork against a glass of water.
now there is a corksniffer tuning?
ive seen everything. good god.
hah, ive got the pitchblack cuz its small and has a huge screen. i tune to 440 though. im so cliche.
I'm definitely cliche. I can't think of a particular reason to use any other setting. Maybe I should try it?
Carbon comp resistors work best at 432KHz. It's the frequency that the planets resonate at....
I like the Korg Pitchblack, it's about as accurate as my Seiko 747 tuner which is amazingly accurate. What more do you want from a tuner? Umm, Ok, the Pitchblack is true bypass, so no tone loss.....
What I have noticed on a couple of recordings is a slightly higher-tuned sound, Guitars are tuned somewhere between Standard tuning and Standard-sharp (I don't know if that's the correct way to express it).
Has anybody noticed something similar?
Well, it sounded a little silly at first until I read:
"The original Stadivarius violin was developed to resonate at 432Hz"
The makers of those instruments knew more about resonant tones than everyone that has ever looked at this board... combined.
Perhaps I'll give it a whirl.
If it works, I'll make sure to look down my nose at all of you
-chris
-chris
"I've traveled the world and never seen a statue of a critic." -L.B.
- soulsonic
Hey, I just want mess around with different tunings, and I figure that if I got a fancy tuner it should be able to do that, otherwise I'd just stick with my cheapo Sabine one.
I don't worry about true bypass because I don't use a tuner on the pedalboard because I don't tune during a set - I tune before the show and that's usually enough... if a string gets really off, I can always get it back in by ear without a tuner anyway. Also this makes it easier for the whole group to share the same tuner (which can be a big help to getting everyone together
This you probably already know, but anyway...
Regarding alternate tunings, one that I like a lot and kicks ass consists of dropping the sixth string to C and the fifth to G.
I got it mentioned by a guitar player named Jeff Kollman (I'm sure he's not the first one using it, just aknowledgeing him), before that I had only tried the old E dropped to D.
You need some beefy strings, though.
