Switchable PS
Posted: 15 Feb 2023, 16:01
by kiltro
Hello,
I'd like to desig a PS for my pedals.
Apart from the usual 9V outputs, I'd like a swtcihable 9-18V (9-12-18V).
I was wondering what's the most efficient way to do this. I was going with the usual variable regulator, but at 9V it would have to dissipate 9V...
Is there any better way? Multiple secondary transformer maybe?
Re: Switchable PS
Posted: 15 Feb 2023, 16:08
by FiveseveN
Re: Switchable PS
Posted: 15 Feb 2023, 17:13
by kiltro
Forgive my noob question... wouldn't that make it very noisy?
Re: Switchable PS
Posted: 15 Feb 2023, 17:29
by plush
kiltro wrote: ↑15 Feb 2023, 17:13
Properly designed switch-mode converter can have as little noise as a linear power supply, or even less.
Re: Switchable PS
Posted: 15 Feb 2023, 21:04
by kiltro
Nice, but not so easy probably.
So the switch would activate or baypass the converter, right?
Re: Switchable PS
Posted: 16 Feb 2023, 06:59
by FiveseveN
kiltro wrote: ↑15 Feb 2023, 21:04
And feed your pedals the unregulated output? Have you thought this through?
Google says About 2,920,000 results for "adjustable DC buck converter", and as far as I can tell
most are adjustable. There are many many chips to choose from, which is why I've kept it vague: you'd have to pick whichever suits your voltage, current, efficiency, noise, frequency etc. requirements.
Re: Switchable PS
Posted: 16 Feb 2023, 07:20
by plush
Quite easy, actually.
You'll just need to invest a couple of hours for your research and use automatic calculators, such as TI Power stage designer tool.
Most of the stuff has already been done for you.
Re: Switchable PS
Posted: 16 Feb 2023, 10:21
by phatt
Hi Kiltro,
An LM7809 would have no trouble dropping 9volts, They are rated up to 1Amp. FWIW, I use a Laptop power supply which delivers 19VDC at 4Amp and then use an LM7809 for the lower voltage pedals.
IIRC I just added a series 220R resistor before the Reg chip and a small heat sink to be on the safe side but it only runs warm.
My Pedal board is silent and has run flawlessly for the last 6 years.
Phil.
Re: Switchable PS
Posted: 17 Feb 2023, 12:57
by kiltro
Thanks Phil
Re: Switchable PS
Posted: 17 Feb 2023, 17:40
by Fender3D
LM317 just need swapping 2 resistors...
Re: Switchable PS
Posted: 22 Feb 2023, 01:11
by ansil
Perhaps I am unclear were you wanting to be able to switch this for all the outputs or do you want it To have 3 separate taps.
Depending on how much current you are looking for have you thought about using an old laptop power supply one that actually has a transformer in it.
I have an old gateway transformer power supply 19 V 6 amps.
It seeds a small circuit board that has a few 78L05s On it. I also have a 15 Volte line. But I'm just using a zener diode and the cap.
Now keep in mind I did choose this particular power supply so it could run my entire pedal board including charge my ipad, But also because of its really clean output on the Oscilloscope.
Really it is overkill but I had a lot of projects I was powering back in the day. Ipad single ended computer, And monitor. As well as a small amplifier that I built.
