TIMMY (again)
bonehead1972
Post by bonehead1972 »
hello guys!
i built one and sounds pretty good but there is not enough gain.... i measured the resistance across the gain pot and it shows around 45K (some parallel resistance?), after that i disconnected the gain pot entirely and measured the resistance between IC pin1 and pin2 with the same reading....what could be wrong here.....
Thanks in advance
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
The schematic you used would be helpful, along with pics.
A stock Timmy gain pot is 1meg, measured out of the circuit. Some versions use 500k.
You're measuring lots of parallel components that connect those two points, including diodes, internals of the op amp, etc. In-circuit resistance measurements can be tricky to interpret, I wouldn't draw any conclusions.
bonehead1972
thanks for your answer, mauman!
