Situation: I have a full finished Analog Sun kit. It switches successfully, plays on bypass fine, but does not have any output when switched on.
Approach:
1. Continuity (good) - I verified with a continuity checker that both the inputs and outputs were routing into the board (see contiuity.png picture)
2. Grounding (good) - I checked to make sure all of the ground points had continuity between them. They do!
3. Voltages - I plugged in a 9V DC charger and took measurements where I could cross referencing with the circuit diagram (see circuit.png picture) Most of these voltages looked good. A couple of things that stood out:
- Volume Pot - All the voltages on the volume pot were zero. Seems weird. Based on the circuit diagram it appears that it should be getting some voltage out of C3 Capacitor and isn't. That particular capacitor didn't solder well and I may have screwed it up.
- IC1 Pin 7 - In the circuit diagram it shows pin 7 not connected to anything. In my measurements I had 3.9V on pin 7. Kinda weird.
- Is it normal for the volume pot to have all zero readings? Could the pot be bad?
- When I installed capacitor C3 ("MKT 10nF" https://www.musikding.de/MKT-10nF_1 ) I wasn't sure of the direction, could I have installed it backwards?
- Any other approaches to troubleshooting?
