Ammo Can Reactive Load
Posted: 10 Apr 2023, 03:36
I finally got around to designing my DIY version of the Suhr Reactive Load. I was able to simplify the circuit with off-the-shelf parts and retain nearly identical frequency characteristics. I haven't formally measured the AC impedance yet, but spice said it should be nearly the same.
Sine wave sweep of the circuit produced a frequency response almost identical to the Suhr, with the major peaks and dips at the same frequencies. One thing I noted was my design had a steeper rolloff of the extreme low frequencies starting around 30Hz. And mine seemed to have a little bit more high frequency energy at the extremes.
I did all these tests driving them with my Traynor YVM-1 set to be as clean as possible with the tone controls at 50% and the Presence at 0. Both load boxes were set to 8 Ohms and I set the amp to 4 Ohms driving both simultaneously. I got a perfect sine wave throughout the recording (guess the bias is perfect), with the exception of the Ammo Can having a weird little kink in part of the wave. It started from the lowest frequencies and seemed to peak around 150Hz, and then quickly taper off and smooth out around 250Hz. Higher frequencies were perfectly sine. This only happened with the Ammo Can, the Suhr didn't have any kinks. I'm guessing it may have something to do with the inductors I used. One difference is the Suhr has one with a laminated core, and mine has a ferrite core. Maybe something to do with that.
The ammo can is a fun box to use, but drilling that steel is not the fun part. I mounted the bank of resistors directly to the box, and it gets very hot in use, so keep that in mind. If the heat is a concern, you could mount them to a heatsink inside the box, or maybe even bolt the heatsink to the side of the box. Ventilation holes are mandatory, unless you want to run it with the top off.
I removed the fan from the Suhr, because I didn't like the idea of it adding a weird load into the mix. If you want to add a fan to this project, I recommend including a small power supply to run it. I added the shield to the transformer with copper tape. The High/Low level switch gives a boost to the level for when you're using low powered amps. Parts used in my build:
- 6.5mH ferrite core inductor: https://www.parts-express.com/6.5mH-20- ... quantity=1
- 650uH air core inductor: https://www.parts-express.com/Jantzen-1 ... quantity=1
- 250uF 100v Non-Polar electrolytic capacitor: https://www.parts-express.com/250uF-100 ... quantity=1
- 62 Ohm 10w resistor - I used an Ohmite from Mouser, couldn't find this value anywhere else I was buying from.
- 4 Ohm 50w resistor x4 - I used Arcol style aluminum body, found cheaply at All Electronics. They're sold out there now. Mouser is easiest choice, but can get a bit pricey there. But various power resistors are usually easy to find cheap at surplus outlets.
- 10K:10K 1/4w audio transformer Edcor PC10K/10K I modified this by adding a shield with copper foil tape.
- 10K audio taper potentiometer - I used a Tocos RV24 type from Amplified Parts, they're really nice.
- 22nF 400v film capacitor x2 - I used CDE 716P "orange drop" style from Amplified Parts
- 10K 1/2w resistor - I used an RN65 from Mouser
- 47K 1/2w resistor - I used an RN60
- 33K 1/2w resistor - I used an old carbon comp I had laying around. You can play with this value; make it smaller if you need more level boost.
- SPST switch for impedance select - you can omit this if you only need one impedance. Make sure the switch is high current. Look for 10A minimum just to be safe.
- SPST switch for High/Low level select - I actually used a SPDT in my bulid, doesn't really matter. This switch doesn't need to be high current.
- XLR Male Jack - I like to use Neutrik, though the mounting hole is a pain to cut, because you have to file out an odd shape to fit the keying. I used one I had on-hand. I don't remember where I had gotten it, but most likely Mouser.
- 1/4" Mono jack for input - Must use an insulated jack. I used a Cliff brand jack from Amplified Parts.
- 1/4" Stereo jack for line out - Should also be an insulated jack. I used Cliff as above.
- 30cal M19A1 steel Ammo Can - From Harbor Freight https://www.harborfreight.com/metal-030 ... q=ammo+box . I like that the lid comes off easily on this one - makes it much easier to work in. Don't use a plastic ammo can, it will melt!
- Knob for volume control - I used a "Fester" knob from Amplified Parts.
- Solder lug for chassis ground. This is attached to an XLR jack mounting bolt.
- Enough 4-40 bolts and nuts to mount all hardware that needs it. I also used nylon washers on the two transformer bolts.
- 4-40 standoffs x4
- Nylon zip ties to secure components to the circuit board.
- Large hole perf board, 3.5" x 5", for mounting reactive components: https://www.parts-express.com/White-Per ... quantity=1 (sold in pairs)
- Various Wire - I recommend teflon insulated wire so they don't melt from the heat. I used 16AWG for the main speaker level wiring to the load, and 22AWG for the line level. I used some fancy Cardas wire for wiring up the transformer and output jacks, because I had a some on-hand that I had never gotten around to trying. I also used some 20AWG uninsulated bus wire in a few spots, like on the power resistors.
- Piece of cork - I used this between the transformer and the case to give it some cushion
