I built my 1st pedalboard using an aluminum frame and two diy modules made from cast Hammond project boxes.
Module 1 is a power module with an IEC plug + on/off switch. allows me to plug a power cable direct into the board.
Module 2 is a signal in-out patchbay which includes a mono guitar input/ pedalboard input and two outputs (mono/stereo)
Module 2 is my issue, I don't think I have it grounded correctly. The input jack is a metal switchcraft jack which provides a ground to the chassis and a ground point for a buss wire that grounds the 5 other I/O jacks which are the plastic Marshall type. My board is quiet as long as I don't use Module number 2. I get constant hum as soon as I plug in. I'm thinking it's because I've got the grounding scheme bass-acwards. Why am I using the guitar as a ground source? I'm thinking I should use the AC ground from Module 1 as a ground source for module 2. Why am I posting the answer to my own question? Not sure, haven't been on the site for a few years! I guess I was hoping to find a pretty drawing of correct pedalboard wiring
Thanks for reading...
