I decided to make an overdrive on 2n7000, because apart from Zvex SHO, I no longer met the use of these transistors in guitar circuits. The circuit is built on 3 transistors, a green LED is used for bias.
At first, I designed the circuit in LTSpice, but then I adjusted the sound by ear.
I don't play the guitar well, but you can get some ideas about the sound from the video
The initial scheme sounds like this:
Schematic https://imgur.com/SCwqaGR
The changed scheme sounds like this:
Schematic https://imgur.com/qg6GOtK
Perhaps there will be some more changes in the scheme, so this is not yet the final version
