Lizard Queef help
stratmaster32
Post by stratmaster32 »
Hi all,
I built a lizard queef following This guide and need some help debugging.
I didn't have all components to hand so I used 2n3904s instead of the 2n2222s and used a 2n4401 instead of the 2n5088. I also didn't have a 1k pot so instead used a 10k at first and then just rigged up a 1k resistor and a 510R resistor to fix the balance at half.
I haven't been able to get the pedal to work. The led illuminates when the switch is pressed but there is no sound. The pedal also works in true bypass mode.
I have tried everything: reflowing the solder joints, running a knife down the strips of the tagboard to clean any shorts, used a multimeter to test continuity between the strips, reseated the transistors in multiple orientations.
I just cant get it to make a sound when the pedal is engaged. Oddly enough - I can hear sweeping through the amp when the volume pot is turned but there's no signal from the guitar.
Any help would be greatly appreciated and I've probably just made a rookie, idiotic error.
https://imgur.com/a/oUO0T0Q Here are some photos of the build.
Thanks,
SM
stratmaster32
Q1
C = 0V
B = 0.551V
E = 1.039V
Q2
C= 3.393V
B= 0.928V
E= 5.95V
Q3
C = 0.804V
B = 1.311V
E = 8.58V
Q4
C= 5.90V
B= 5.26V
E= 0.816V
D1
A (anode, the non-band end) = 1.029V
K (cathode, the banded end) = 0.547V
D2
A = 0V
K = 9.40V
Frank_NH
Has thanked: 99 times
Been thanked: 144 times
Post by Frank_NH »
Check the orientation of your transistors. Q1 at least should be flipped around based on your voltages.
