I am trying to learn how to design PCB with KiCAD. My first attempt is a simple 3PDT breakout board for true bypass. Before I place an order, is anything willing to give my design a sanity check?
TIA
3PDT PCB sanity check
- plush
0. You forgot to include drill plot - no holes/vias will be made
1. You should increase clearance for both traces (marked yellow) and 3pdt pads
2. There is no need to route additional ground traces with already existing ground plane (blue)
3. There's enough space to thicken the traces twice or trice
4. I recommend you to revisit your 3PDT pads design. I've added mine for reference, which suits both solder log and pcb-style contacts.
