JRC 4558 vs 4559
Posted: 07 May 2023, 12:55
by blaise
I want to build a Tim using Dirtbox layout at
https://dirtboxlayouts.blogspot.com/202 ... e-tim.html and see conflicting informations on the JRC 4558 vs 4559:
According to this page
https://html.alldatasheet.com/html-pdf/ ... 4558D.html, the only difference would be the slew rate (1 for the 4558 and 2 for the 4559), so that a 4558 would be a poor substitute for a 4559 in this application, right? If so, what would be a proper alternative?
Re: JRC 4558 vs 4559
Posted: 07 May 2023, 13:47
by mauman
These two are fine substitutes for each other in a guitar pedal, you won't hear a difference.
- JRC 4558 vs. 4559
Posted: 07 May 2023, 16:16
by blaise
Thanks @mauman
My initial thinking was that the slew rate was a major factor since we are trying to overdrive the diodes and that the 4558 would generate only half the voltage of the 4559. However, thinking in log scale, halving the slew rate will only cut 3db to the output voltage which will still be sufficient to overdrive the diodes.
Am I right?
Posted: 07 May 2023, 18:58
by FiveseveN
But the Tim is only demanding around 40 dB from the op amp, you've got plenty to go until you run out of bandwidth.
Posted: 07 May 2023, 21:18
by blaise
FiveseveN wrote: ↑07 May 2023, 18:58
That makes a lot of sense now. Thanks a lot.
Posted: 19 Jun 2023, 01:54
by ding127063
The actual difference between the two parameters may not be so great, JRC4558, JRC4559 and JRC4562 architecture is the same, it is likely to be the same assembly line production, by screening the monomer parameter error to distinguish the model.
