EH Small Stone
espinete
Post by espinete »
Hi all !
The pedal has no effect when engaged. It also has a big volume drop.
There was a shortcut due the bad shape of the "Color" switch. I cut the common leads and the ones at the down position and put together.
One of the transistors was dead, I put a bc239 (same pinout as the bc309's.)
I guess I can use ca3094's instead of eh1048 wich are completely impossible to find. Now there are five ic sockets for the op amps.
The ca3094 near the pot area measures 0.70v @ pin 6 with the potentiometer at maximum.
The rest of the op amps measurements at pin 6 :
Ca3094 5.42v
Ca3094 5.42v
Eh1048 3.23v
Eh1048 3.23v
I installed a new b100k (Lin) pot.
I saw a 10uF e.capacit but there is printed text saying 33uF in that component, so I changed it to 33uF.
I also changed the first resistor of the power supply 43R to 47R.
The ca3094 ota chips are very expensive. I was thinking about to buy some chinese copies for my proves believing they have the same pinout but I'm not sure.
Any help will be welcome and appreciated
CheapPedalCollector
Has thanked: 432 times
Been thanked: 141 times
Post by CheapPedalCollector »
Chinese ones are gonna be fakes, just get the CA3094s. That is what the EH chips are, they are just house branded. They did that a lot to keep people from stealing their designs.
