Tim voltage divider
I still am trying to understand the schematic and layout of the Tim from http://dirtboxlayouts.blogspot.com/2022 ... e-tim.html or http://effectslayouts.com/wp-content/up ... ld-Doc.pdf.
It seems to me that R9-R10 (or in the vero layout H-N14 and K-N7) is a voltage divider providing 4.5V. Since we feed 9V, shouldn't R9 and R10 be equal in order to get 4.5V?
That would make sense, but the schematic on this old thread seems to indicate a 4.5V biais. Any idea which is correct?
viewtopic.php?p=161586#p161586
- mauman
Allowing for different versions across time, the best I can tell, Tim and Timmy were biased slightly differently. The schematic corrected by Paul in the Tim thread you linked shows a 4.5v bias (at least, at that time.) The Timmys I have seen all use a 4.9V bias (8.2k/10k divider pair.) The Tim vero layout you linked is from a schematic "based on the Tim", not a clone, and it has the Timmy (not Tim) voltage divider pair and 4.9V bias. But in the end, there's not a big difference between 4.5 and 4.9V.
Time for experimenting with the bias voltage then. I quickly compared the Vero layout and the schematic and they seem identical. I need to double check the part with the clipping diodes.mauman wrote: ↑10 May 2023, 14:54 Allowing for different versions across time, the best I can tell, Tim and Timmy were biased slightly differently. The schematic corrected by Paul in the Tim thread you linked shows a 4.5v bias (at least, at that time.) The Timmys I have seen all use a 4.9V bias (8.2k/10k divider pair.) The Tim vero layout you linked is from a schematic "based on the Tim", not a clone, and it has the Timmy (not Tim) voltage divider pair and 4.9V bias. But in the end, there's not a big difference between 4.5 and 4.9V.
- paulc
Hi Blaise, That 8k2/10k divider really doesn't matter. That was done to try and eke out some extra headroom out of the 2nd stage when a battery was running low. It's always been there for both Tim & Timmy pedals so the posted schematic is wrong. With a healthy pwr supply you will be hard pressed to hear any difference honestly.
Paul C
Paul C
