ibanez cpl comprssor
jmpj45
Post by jmpj45 »
Hi i bought a ibanez cpl compessor really cheap. I new it didnt work well i have checked everything. i cant see anything burnt or broken what its doing is it will pass a signal when the pedal is turned off soon as you turn it on the signal stops. I even put a new ba6110 chip in it didnt do anything doing the same thing got a signal in bypass signal stops when you turn it on. I have checked all the voltages everthing is good. So would anybody have any ideas what is wrong with it. Here is the schematic i cant find the cpl schematic so i have to use this one its the same cirquit.
ibanez_cp10_sch.pdf
(80.99 KiB) Downloaded 37 times
Lani
my favorite amplifier: Bassman 5f6a
Completed builds: .....ummmm yeah. Too many to list.....
Has thanked: 107 times
Been thanked: 74 times
Post by Lani »
I would check the jfets off of the bypass flip flop... Could try jumping D to S on them to see if you get signal then...
Has thanked: 218 times
Been thanked: 857 times
As far as I know the CPL and the CP10 are identical. Start by verifying supply voltages.
jmpj45
Post by jmpj45 »
I have checked all supply voltages bias voltages everything is good.
jmpj45
Post by jmpj45 »
I’ll check the Jfets get back to you thanks.
jmpj45
Post by jmpj45 »
I jumped the jfets it came on. I put 2 new jfets in it works perfect thanks lani. I guess the 15$ I bought it for wasn’t to bad lol.
Lani
Post by Lani »
Nice!! No worries homie!! Now you should have an extra ba6110 to play around with! 8)
jmpj45
Post by jmpj45 »
Yes I bought 2 ba6110 I got 2 now.
