I'm pretty new to circuitry. I have built some kits and recently re-housed and modified a JHF1 Dunlop Fuzz Face. Works awesome. I'm a germanium transistor collector and have learned a bunch over the past year. I just bought a Newmarket Transistor amplifier circuit (pre-made) from the 60's. The Reverb ad said something about being a Deacy amp. It has a basic schematic diagram for the wiring but I've tried a bunch of different things an I can't get the thing to work. I figured I would ask if someone can help me understand what wires go where and where to solder them on the jacks and the only pot. I figure I'll mod it later but I just want to make sure it works first.
Pics are attached.
Q's
1 - Where does the input jack signal go to? The pot? Which lug? Which is in and which is out? Do I need to ground the pot? Do I need to ground the input jack?
2. Where does the pot wire/signal go in the circuit? Hole C?
3. Which hole is ground? Where should I solder the circuit ground wire? A jack?
4. Where do I solder the 9 volt red positive and black negative? Do I need to have an on/off switch?
5. I'm not attaching wires to a speaker like the outline shows. Where do those two wires go? The output jack? Do I need both wires?
6. Two holes look like they indicate 'lamp'. Does that mean I can add an LED through one of these holes?
I really appreciate any help anyone can give. I'm about to smack my head off a wall as I don't know what my neck steps should be after doing an ineffective troubleshooting.
