Pedal Surfy Bear Fet reverb ( Fender® 6G15 )
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
hello everyone,
I wanted to make the reverb based on the Fender 6g15 Reverb Unit, has anyone tried it with fets?
[/media]
thanks
Captura de tela 2023-06-13 131617.jpg (54.73 KiB) Viewed 609 times
andare
Been thanked: 9 times
Post by andare »
I don't understand your post. The Surfybear is exactly that.
I built one of those kits. They are not available anymore.
IIRC someone has made a PCB of the SB on Reddit.
It's worth changing the way the Mixer works because it sucks tone like crazy, just like the original Fender units.
I read somewhere that the dry and wet signals can be worked into two separate pots but I can't find the post anymore and I don't know what else would be required.
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
andare wrote: 16 Jun 2023, 08:45 I read somewhere that the dry and wet signals can be worked into two separate pots but I can't find the post anymore and I don't know what else would be required.
I think this might be it: https://www.diystompboxes.com/smfforum/ ... msg1093202
andare
Post by andare »
mauman wrote: 16 Jun 2023, 16:53
Yes.
I have the dry kill switch mod in my Surfybear kit but since I don't have a Boss LS2 it's not very useful. I'd like to have Independent volume controls for wet and dry. I know how to get the two signals from the PCB into separate pots, I don't know how to connect their output to the output jack. I suppose it's not as simple as connecting the wiper of the two pots to the tip of the output jack. Or is it?
andare
Post by andare »
It's this thread here viewtopic.php?f=7&p=285383#p285383
OP used summing resistors from the two pots to avoid crosstalk. I think he used 100k but I think much less would also work. The active option in that thread is actually better because it allows to make the signal louder like with the Surfybear Metal.
