PDF:
Nevermind Rolf Harris...
The most wacky, but perhaps most interesting project I've come across in electronic magazines: couldn't it be adapted to a freaky guitar effect? It takes a microphone input... so it literally already a sound processing devices. Should replace the GE transistors with SI and make it negative ground, but I have a hard time understanding what the transformers do.
A.J. Bassett, Electronic Didjeridoo, Practical Electronics, November 1964 🇬🇧
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
- cspar
Nice.
The transformer 1 & 2 are there in the classic passive ring modulator topology that is common among synth modules and has been used in a few guitar pedals too.
The option of using a transformer (3) to generate the modulation frequency isn't too pedal friendly.
Interestingly, I don't remember seeing a GE driven "passive" ring modulator before.
Thanks again Modman.
"Just because the forgoing circuits have produced results there is no reason experimenting won't lead to added results." L. E. Darling, in his article containing the earliest published vacuum tube synthesizer circuit, Popular Science Jan 1920
- Ben N
As cspar says, T1 & T2 are phase splitters for the two inputs to the ring mod; T3 is a weird way to turn mains supply into a 50/60 hz carrier signal. I think most of us here would prefer to build the oscillator for this purpose.
