Here's the list of the components seen (except resistors) on the pcb ASSY 5600-9520 produced in 2005 :
Capacitors :
-C1,2,3,4 : 2200uF 63v Nichicon CE 85° (LQ/M) LS=22mm
-C6,8,9,11,13,14,15,18,29,30,31,38,39,40,43,44,45,46 : 100uF 50v BC036 T8 LS=9mm
-C7,12 : 10uF 63v BC036 T8 LS=5mm
-C50,C51 : 10uF 63v BBC036 T4 LS=5mm (under pcb: C50 between R93 and Q24 // C51 between R90 and Q24)
-C52 : yellow tentale ? MEC 68J NPO
Can someone please help me to confirm the brand/model of the grey caps C43,44,45 100uF 50v ?
- U5 capacitors
At first sight, I'd say Vishay Cap BC036 from 2005 :
-Rated RMS ripple current at 100 Hz, 85 °C = 250mA
-Max. leakage current after 2 min at 50v = 33uA
-Max. impedance at 10 kHz and 20 °C = 0,7 ohm
-Useful life: 3000 h at +85 °C
I will perform a full recap, what would you advice as replacement : long life, low ESR, high ripple current ?
Panasonic FM ? The same Vishay but newer ?
Diodes :
-D1,2,3,4 : 1N4004
-D5,6,7,8,9,10,11,12,13,14,15,16,17,18 : 1N4148
-ZD1,3 : unreadable
-ZD2,4 : unreadable
-ZD5,6 : unreadable
OPAMPs & Tansistors :
-U1,2 : National LF412CN (code JR56RD)
-Q1 : O.N. TIP31CG + large heat sink
-Q2,3,9,13,17,21,24 : C546B
-Q4 : O.N. TIP32C + large heat sink
-Q5,6,7,8,12,16,20,25 : C556B
-Q10,14,18,22 : ST BD139
-Q11,15,19,23 : ST BD140
Special resistors :
-VR1 : trim Bourns W203 545C (Bourns part 3296)
-RN1 : Dale Resistors Network 104G MDP1603 (Dale part 0418)
-R100 : added under pcb 475R 1% 1/4w
Enjoy
Arno
